I am having lockup in Windows 7, 64-bit & 32 bit, but no BSODs. Nothing in the Event Viewer. It takes from 30-90 minutes to get the PC locked. I have already performed the following:
- Ran the memtest86 with no issues
- Change from default memory settings to X.M.P.
- Updated all windows updates and drivers
- Tried with one chip at a time but no luck
- Thoroughly tested the video card with their diagnostic test
I do not have my processor to OC yet. By default, my mobo is recognising this memory is 1600Mhz. When I use XMP, it shows 2133MHz. I just want to stablize the system at the moment. Any help will be greatly apprectared.
Here are my system specs:
Motherboard: ASUS P8P67Pro Rev 3.1 New P67 B3 Revision
Processor: Intel Core i7 - 2600K, 3.4GHz, 8MB Cache, LGA1155, 95W
RAM (memory): G.Skill, F3-17000CL9D-8GBXM, DDR3-2133MHz, PC3-17000 4096MB x 2 (8GB Total)
Video Card: EVGA NVIDIA GEForce GT520, 1024MB DDR3 PCI-E
Power Supply: Corsair Professional Series HX750
Hard Drives: Seagate ST3320620AS (320.0GB, 7200RPM, 3Gbs) x 2 (RAID0 - Striping) for OS
Seagate ST500DM002-1BC142 (500.1GB, 7200RPM, 6Gbs) x 2 (RAID1 - Mirror) for Data
DVD: LG HL-DT-ST BD-RE WH12LS39 ATAPI
Case: Antec 900
Multiboot: XP 32-bit, XP 64-bit, Win7 32-bit and Win7 64-bit
Windows 7 32-bit and 64-bit are freezing in about 30-90 minutes of the login. Both XPs are fine.
Case: Antec 900
