I need some advice becouse i'm stuck installing this memory kit in my PC
I'll try to explain my issue. When i install it and use the XMP 1 or 2 at 1866 as it rated, after save and exit my PC enters in a continuous loop turning on and off and i cant access to the bios, at this point i have to push the (clear CMOS switch) to allow me reset values and go back to set bios again.
I tested:
-XMP 1 or 2 profile can't boot or access to bios(continuous loop turning on and off before i can see the asus logo or bios post)
-All in AUTO (same problem above)
-Typing different manual setting (different timing setting and voltage 1.50v +0.10v) no luck.
I set it to 2133 10-11-10-30 1N 1.60V and it worked, but i received an error i know it is not set to work at this speed.
Now i'm running it at 1600 9-9-9-24 1N 1.50V and it work fine without any error, But i'd like to run it at 1866 as it rated.
My system spec: MB: Asus Maximus V Gene with latest BIOS. Processor: Intel I5 3570K @4.2 1.14V, EVGA 670, Crucial M4 128GB/ WD500 GB
I tested:
