Hi, my system is as follows
CPU: i7 920, default clocks
Motherboard: Intel dx58so
Memory: G Skill Pi series DDR3 1600 (f3-12800cl8tu - mine is the silver colored ram, not the black color revision, though they appear to have all the same specs)
My motherboard happily runs my ram at 1066mhz...at 8-8-8-19 automatically, but if I use the "XMP" memory setting, it runs it at 1600mhz instead...except it will not boot after the next restart. If I rev up the QPT to 1.35, and the other memory voltage to 1.74 instead of 1.65, as well as loosen the timings to 9-9-9-24 it works. Thoughts?
