I am now using an ASRock Z77 Extreme 4 motherboard, with the same Core i5-3570K CPU as before, BIOS version the latest one (2.00, 7/17/2012).
I originally bought two dual-channel kits of G.Skill F3-10666CL9D-8GBRL, for 16 GB total RAM. I had to RMA two of the sticks, as they caused bluescreens and prevented resuming from sleep when installed. The replacements for those sticks have been fine, but now I am having problems with the other two sticks (the pair remaining from my original order).
Now I get bluescreens at random, and when I attempt to reboot the machine after one of these bluescreens, the motherboard gives a "RAM not installed" error code. Even if I leave the system powered off for several hours after that, I have the same error again upon attempting to start up. The only way to use the machine is if I only have the two newer sticks (8 GB RAM) installed.
I had the RAM installed so that consecutive serial numbers were paired by channel (two in channel A, other two in channel B), and they do run in dual-channel mode.
I do not overclock and had done no adjustment of RAM settings in BIOS. Going into the motherboard's BIOS yesterday, however, I noticed that RAM voltage was set at 1.585 V by default. That seemed wrong, so I manually set it to 1.500 V. That didn't fix the problem, unfortunately.
Here are a bunch of other settings from my motherboard's BIOS, which are listed under overclocking settings:
CAS latency: 9
RAS to CAS delay: 9
Row Precharge Time: 9
RAS Active Time: 24
Command Rate: 2N
Write Recovery Time: 10
Refresh Cycle Time: 107
RAS to RAS delay: 4
Write to Read delay: 5
Read to Precharge: 5
Four Active Windows: 20
CAS Write Latency: 7
ODT WR A/B: Auto
ODTNOM A/B: Auto
MRC Fast Boot: enabled
This is all default settings. I haven't tweaked a single thing, except for lowering the RAM voltage to 1.500 V from the 1.585 V it was set to for some reason.
Any ideas?
CAS latency: 9
RAS to CAS delay: 9
RAS Active Time: 24
Command Rate: 2N
RAS to RAS delay: 4
ODT WR A/B: Auto
ODTNOM A/B: Auto
Any ideas?
