I just recently (last week) built my first computer, and everything ran fine for the first 5 or so days, but now I'm getting constant BSOD's, usually saying the reason is Memory Management. At least 50% of the time I try to run any games they will just crash and my system BSOD's.
I hadn't overclocked the memory but the reason i decided to get this particular model was for possibly doing so in the future, so i had only tried setting the target DRAM speed to 1333 and 1600 MHz, both of which had the same issues, as well as having my BIOS simply load the optimized defaults for my hardware.
I ran the Windows Memory Diagnostic and it says there is an issue with the hardware, as well as ran Memtest86+, which, after only just a couple hours had well over 1 million errors.
At this point, I can't figure out if the memory is defective and will need to be replaced or if I can do anything about it and maybe just have it set up incorrectly.
For reference, my CPU is an Intel Sandy Bridge i5 2500k @ 3.3 GHz and my Mobo is an ASUS P8Z77-V LK.
On a note about my mobo, I've noticed a lot of people stating that when setting up certain memory sticks, the CPU-NB voltage will need to be tweaked slightly, as well as the CPU bus, but I've looked through my entire BIOS and cannot for the life of me find where to change ether of these settings, unless it would be called something else?
Any help would be greatly appreciated, and if I forgot to mention anything I apologize, I will reply with any information I might be missing
