I bought 4 of these 8GB sticks to upgrade my 2 computers (2x8GB in each PC). Out of the 4 sticks I purchased 3 are working perfectly but one seems to be faulty.
I have Memtested that stick run at 1600MHz 10-10-10-30-2T timings as per G.Skill specifications programmed in XMP, as well as standard SPD specs 1333MHz 9-9-9-24-2T. Both settings come up with errors. Errors pop up in both memory slots A1 and B1 at 1.5V in a Gigabyte GA-P67A-UD4-B3 with i5 2320. All three other sticks tested in the same configuration without a problem.
Pictures:
Strangely, when I move this bad stick to my other PC (i5 2500K, Asus P8Z68-V Pro) Memtest passes but is unstable running IntelBurnTest in Windows. The three other sticks fly through IntelBurnTest in this PC without a hitch.
Do I have a bad module? Thanks.
Pictures:
