I believe I have a faulty memory stick but wanted to see what you all think:
* ASRock P67 EXTREME4 GEN3. BIOS version: 2.20 (newest as of June 6, 20120)
* CPU: Intel Core i7-2600
* Memory: G.SKILL Ares Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3
12800) F3-1600C9Q-16GAB
* GPU: MSI N560GTX-Ti 448 (GeForce GTX 560 Ti). Driver: 301.42 (newest as of May
22, 2012)
* Windows 7 x64 & Ubuntu 12.04 x64. Blue screens on Windows. Also memtest
failures (thousands almost immediately)
* OCing: No
Per http://www.gskill.com/products.php?index=477 I believe the mobo supports
that memory without further settings. I did try to manually set timings 9-9-9 24
2N in the BIOS but that did no good.
Then I removed two of the sticks and the problem went away. Then (to verify it's
not the mobo) I replaced the two working sticks with the other two and got
memtest failures again. Which leads me to believe one set of the 4 sticks is
broke.
Thoughts? Time to RMA?
Another question: Since my computer is working with the 2 working sticks (8GB),
can gskill send me a replacement before I return the faulty ones? I'd hate to
have my computer none-operational while I wait.
Thanks!
Philip
22, 2012)
* OCing: No
broke.
Thanks!
Philip
