Hi got some problems with F3-10666CL9D-8GBRL (4Gx2).
Getting BSD all the time even when idle and data corruption.
Changed the HDD so its not the problem.
Using ASUS P8H61-M LX PLUS REV 3.0 with i5 2310 LGA1155 2.9GHZ...is the memory compatible with this MB?
Updated bios to latest 4104 and the problems are worst could not even reinstall Windows 7 x64 saying files are corrupt (the dvd is fine) so the problem is not from softwares.
Used memtest and I have more than 1 million errors.
Tested each ram individually on each slots with less errors but still many.
Tested with rams from another PC with no errors so the mobo is not at fault.
So I guess the memory is bad or my voltage is not set right.
No OC, default bios settings:
Memory at 1333mhz
CPU at 2.9ghz
CPU voltage 1.125v
DRAM 1.5v
VCCIO 1.05v
CPU PLL 1.8v
PCH 1.05v
DRAM timing at default
Hoping to repair this with some help from you folks before doing RMA so what should I tweak?
Memory at 1333mhz
CPU at 2.9ghz
CPU voltage 1.125v
DRAM 1.5v
VCCIO 1.05v
CPU PLL 1.8v
PCH 1.05v
