I recently built a new computer last year and just noticed that my memory is only showing as 1600. I understand to get the rated 1866 speeds I will need to manually configure
the timings but I can't find any on the forums with a similar build to mine. I have never manually configured timings for memory and am seeking the knowledge of some experts.
(don't wanna fry my pc). It has been running stable at 1600 for about 6 months but just want that little extra oomf. Below are my system specs. Please let me know if you need
any more information.
Motherboard
ASUS Sabertooth 990fx (Bios 1208)
CPU
AMD FX-8150 3.6ghz
Memory
Gskill Sniper F3-14900CL9D-8GBSR (2x4GB)
Also, the current *AUTO* timings are
DRAM CAS# Latency 11
DRAM RAS# to CAS# Delay 11
DRAM RAS# PRE Time 11
DRAM RAS# ACT Time 28
Command Rate 1T
DRAM Voltage 1.503-1.506v
Are these the only settings I should be concerned with?
Motherboard
CPU
AMD FX-8150 3.6ghz
Memory
Command Rate 1T
