Hi guys, i just had a new pc built for me and am having a couple of issues which i dont know the cause of.
First of all here are my specs:
CPU: Intel i5 3570k
CPU Cooler: Noctua DH-14
RAM: G Skill F3-14900CL8-4gbXM (16 gb total dual channel, 2x4+2x4)
MB: Asus Sabertooth Z77
SSD: Gforce 120GB GT
GPU:2x EVGA GTX 680 Signature in SLI
Sound: Asus Xonar STX
Case: Thermaltake Level 10 GT
Power: Corsair 1050HX
OS: Win 7(sp1) 64-bit
Issue: Whenever i do heavier processes for a longer time, such as playing games or graphics editing (mainly cryengine 3 and sketchup both combined), after a while my computer freezes, restarts itself and gives 4 (yes 4 exactly) quick beeps. Ive updated all drivers, even did a motherboard bios flash update but still same issue. Ive checked everything is seated properly too. I was recommended to do a gpu bios update but cant figure it out (since i cant get the topology of my nvidia cards).
Also, particularly when im editing in cryengine 3 i hear a small "whining" like noise coming from my pc, when i minimize cryengine it goes away, and when i open it again it starts again, as if the computer is under some strain.
Final thing, and i this might not be a problem at all, but whenever i power off or power on the PC it ends/starts with a click that i assume is coming from the power supply, i've never heard noises like that with previous pcs, so the clicking noise just sounds very unnatural to me.
For the computer freezing and shutting down i think i narrowed it down to the RAM. I tried running memtest (the windows version) and at some point during the test my computer will always crash (tried it 4 times and 4 crashes during!) but then i was advised to try memtest86+ instead, so i created a bootable cd from www.memtest.org and ran the test. Everyone says that the test will take a long time (around 12 hours or so), but for some reason my test only lasted 10 mins. It performed two tests, found no errors and booted to windows after 10 mins. Am i doing something wrong with memtest86+??
so im a bit confused atm, since one memtest (downloaded from http://hcidesign.com/memtest/) crashes my computer so i would think the RAM is the issue, but then the 'proper' memtest (memtest86+) shows no errors, but only works for 10 mins...
any ideas are much appreciated guys!!
thanks!
CPU: Intel i5 3570k
thanks!
