Recommendation for Dell Optiplex 990
  • Recommendation for Dell Optiplex 990
    Hi all,
    I'd like to add 2 x 4gb to a Dell Optiplex 990. Dell specs say the mobo uses a Q67 chipset, and calls for Non-ECC dual-channel 1333MHz DDR3 SDRAM. This unit has a i5-2400 CPU.
    There are a number of G.Skill packages at Newegg that match these specs, and I'm not sure which would work best with the 990. These are some of Newegg offerings that I've identified so far:
    F3-10666CL9D-8GBRL
    F3-10666CL9D-8GBSR
    F3-10666CL9D-8GBXL
    F3-10666CL9D-8GBNT
    These have nearly identical specs and are the same price at Newegg.
    Assuming that physical fit/interference is not an issue, which of these would be best?
    Thanks,
    With a Dell, I'd go with the Snipers, they are (I think) the most versatile set of the four
