abnormal memory, 64gb 1600mhz kit
  • abnormal memory, 64gb 1600mhz kit
    When i put all 8 sticks, d1 and d2 read as abnormal, and it loads only 48gb of ram. I took the two sticks from d1 and d2 and put them in the two right next to them (i guess c1 and c2), i left the d1 and d2 empty, and it loaded all the 48gb fine, which could mean that the sticks are fine?
    Then i put these two back into d1 and d2, leaving c1 and c2 empty, and again it worked fine.
    How should i troubleshoot this?
    Holy crap that's a lot of memory.
    To troubleshoot sticks for defects, run Memtest86+ with one stick at a time.
    What CPU/Mobo are you using? You could be limited by those, in which you could try a lower frequency (offset with tighter timings for performance).
    64GB of RAM. That's...quite awesome!
    AMD's Official AM3/AM2+/AM2 Performance Tuning Guide
    AMD's Official FX AM3+ Performance Tuning Guide
      It's a 3930k and a asus sabertooth. I don't see xmp 1.3 profiles either, but i'm new to all this, this wasnt around when i was building my last build.
        Pailhead, have you on my list for GSkill Tech to take a look at when he get's some time
