I recently purchased two 16GB kits of DDR3 GSkill RAM memory:
G Skill Ripjaws Z, 2x16GB, DDR3 PC17000 2133MHz Kit for Intel X79 Quad Channel Platform -
model number: F3-17000CL9Q-16GBZH.
I've found out that on my system (Asus P9X79 motherboard + Intel Core i7 3930K) two 16 GB kits of this memory won't work together, the system won't be stable, and it is hard to configure it, I read that on the Asus forum just today;
now I do not know what to do: should I exchange my two 16 GB kits with different kit combinations?
Will the technical support help me, and replace those kits with the right ones?
I would like to have 32 GB of memory on my system that I can configure and optimize properly, if I keep the ones I've got they will never work well in my computer.
I would like to know if you can give me support for this, because I don't think the vendor, after two weeks now, will take the items back.
Thank you.
Thank you.
