I have the G.SKILL Trident X Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 2666 (PC3 21300) Desktop Memory Model F3-2666C11Q-16GTXD
So far, 2133 works at 1.65 volts tested stable. I cannot get these to run at 2666. Manually set, not using XMP, memory timings at 11-13-13-35 or auto timings, does not post and you get post code 23. When the memory and timings are set to 2666, the board will auto volt vccio and VSA to 1.25 and sets Power management frequency to .8 volts. It does this by itself. I've also reduced these from 1.25 in .25 increments down to 1.1 and same results.
I have also tried to relax timing to 15-15-15-40 and set tertiary timings to all 5s as recommended on our forums by a guy that was able to reach 2666....I sent a PM to him for an explanation but no reply yet. Those relaxed timings above and I Still get code 23. I can get 2400 to post but it's not stable at 1.65 volts in memtest to about pass 6. I believe it also defaults to the above mentioned voltages.
If these dimms are stable in memtest at 2133, then I have good dimms, correct or do I need to have newegg send me a new set?
Can anyone help to make suggestions? So far, I get either post code 55 right after bios save and exit and then post code 23
I am using bios version 1.04 beta
