I am putting together a build with the following configuration:
Mobo: Asus P8Z77-V-Pro
CPU: Intel i7-3770
It will not OC.
My local PC shop supplies the following G.Skill RAM:
Ripjaws-X F3-12800CL9D-8GBXL (2x4 GB) which is not in the QVL.
When using two sets of those (=4x4 GB), is there a difference to the set
F3-12800CL9Q-16GBXL(XMP), which is listed in QVL ?
Which PC1600 - 16GB set do you recommend for a reliable stable system?
CPU: Intel i7-3770
It will not OC.
