I really need some help to configure the bios of my asus board. It seems like it just set completely wrong settings for my ram. (I get really annoying freezes)
I use the F3-10666CL7Q-16GBXH two times, so I got 32gb ram. May this cause some problem in the bios?
Setting in the AI Suite:
I will edit this to submit my bios setting soon.
EDIT:
BIOS settings:
AI Overclock Tuner -> XMP
XMP DDR3-1333 7-7-7-21-2N-1.5V -> Profile #1
BCLK Frequency -> 100.000
CPU Strap -> Auto
ClockGen Full Reset -> Enabled
Turbo Ratio -> By all Cores
Memory Frequency -> DDR3-1333Mhz
DRAM Timing Control:
Primary:
Cas Latency -> 7
Ras to Cas Delay -> 7
Ras PRE -> 7
Ras Act -> 21
Command Mode 2
Secondary:
Ras to Ras Delay -> 4
REF Cycle Time -> 107
Write Recovery -> 10
Read to PRE -> 5
Four Act Win Time -> 20
Write to Read Delay -> 5
Write Latency -> 7
Third
TTDR 0
RRDD 2
WWDR 3
WWDD 3
RWDR 2
RWDD 2
WRDR 1
WRDD 1
RWSR 2
CCD 0
Latency:
What -> CHA/CHB/CHC/CHD
RTL D0R0 -> 33/31/33/31
IOL D0R0 -> 5/4/6/5
RTL D0R1 -> 33/31/33/31
IOL D0R1 -> 5/4/6/5
RTL D1R0 -> 31/31/31/31
IOL D1R0 -> 4/5/4/5
RTL D1R1 -> 31/31/31/31
IOL D1R1 -> 4/5/4/5
That's all i know. I hope I didnt miss some settings.
I would be very thankful if there's any help!
EDIT:
BIOS settings:
CPU Strap -> Auto
Primary:
Cas Latency -> 7
Ras PRE -> 7
Ras Act -> 21
Command Mode 2
Secondary:
Read to PRE -> 5
Write Latency -> 7
Third
TTDR 0
RRDD 2
WWDR 3
WWDD 3
RWDR 2
RWDD 2
WRDR 1
WRDD 1
RWSR 2
CCD 0
Latency:
IOL D0R0 -> 5/4/6/5
IOL D0R1 -> 5/4/6/5
IOL D1R0 -> 4/5/4/5
IOL D1R1 -> 4/5/4/5
