F3-17000cl11-4gbxl
  • F3-17000cl11-4gbxl
    Hello!
    I have been having trouble with getting my memory up to 2133 as it states. I have an Asus Crosshair Formula V Motherboard with BIOS version 1402 with the AMD Phenom II 1100T X6. I also have an HIS 6970 IceQ Mix (dunno if the video card is relevant) and an 850w psu. I have tried the xmp setting it had, but it just hangs, any help with this would be greatly appreciated, Thanks!
    P.S.
    So far i'm running at 3559 MHZ and my memory is running at 1740
    How many modules do you have?
    CPU Host Frequency needs to be 267 for DDR3-2133, so set that.
    CPU-NB Frequency should be ~2937 to 3200MHz
    Must raise CPU-NB Voltage to stabilize the memory controller.
    XMP can work instead of manually inputting basic DRAM settings, just don't forget to tweak the above as XMP will not do that.
    Keep us posted on the results!
      I have 4 modules
        From what you show am guessing it's a model # off an individual stick, do you actually have a single 4x4GB set or a pair of 2x4GB sets, reason I ask if it's two sets then XMP won't work as the XMP programming is by the set. If it's a 4x4GB single set you'll still need to follow GSkill Techs instructions, but won't need as much voltage for a single set as you might with two sets. Single set may need to raise DRAM voltage + .05 and CPU/NB probably + .1 to + .15
          I have 16gb total. The xmp does not work. and I tried doing what you said, but no luck.
            sorry, to be more specific I have 4x4
              The MC in your 1100T may not be able to handle 4 sticks at 2133. might try down to 1866 (or possibly 1600), haven't seen many FX-8150 even that can handle the 2133 4x4GB
                well, after some tweaking I have it running at 2134. I re-tried what g.skill tech said. The downfall is that it's unstable. I tried prime95 using small fft's and it freezes my pc. any thoughts? not any options for 1866, will only let me go down to 1776 from 2134.
                  I raised the memory voltage to 1.65 and the cpu/nb frequency to offset mode with 2937 and the cpu/nb to .15
                    Let us know how it goes
