I recently decided to upgrade from 8GB to 16GB of RAM, and after installing the new RAM I'm getting some weird speed readings. I think I set everything right in the BIOS, but for some reason Speccy says my PC3-1700 RAM is running at PC3-10700.
Not only that, but since installing it I have had it hang and force me to do a manual reset multiple times. Most of the time there were no applications running, it just hung on a blank desktop. Any ideas for where to start troubleshooting this kind of issue would be appreciated.
I've got as much information as you could possibly want about my system, but I'm not sure what to include aside from a general system summary, my RAM info, and my motherboard info.
Code:
Summary Operating System MS Windows 7 Ultimate 64-bit SP1 CPU AMD Phenom II X6 1100T 28 ?C Thuban 45nm Technology RAM 16.0 GB Dual-Channel DDR3 @ 666MHz (9-11-11-30) Motherboard MSI 890FXA-GD70 (MS-7640) (CPU1) 33 ?C Graphics TX-NR3007 (1920x1080@60Hz) ATI Radeon HD 4800 Series (Sapphire/PCPartner) 63 ?C Hard Drives 59GB OCZ OCZ-VERTEX2 ATA Device (SATA) 30 ?C 1465GB Western Digital WDC WD1502FAEX-007BA0 ATA Device (SATA) 37 ?C 1465GB Western Digital WDC WD1502FAEX-007BA0 ATA Device (SATA) 36 ?C Optical Drives Optiarc DVD RW AD-7240S ATA Device ELBY CLONEDRIVE SCSI CdRom Device Audio AMD High Definition Audio Device Operating System MS Windows 7 Ultimate 64-bit SP1
Code:
RAM Memory slots Total memory slots 4 Used memory slots 2 Free memory slots 2 Memory Type DDR3 Size 16384 MBytes Channels # Dual DRAM Frequency 666.7 MHz CAS# Latency (CL) 9 clocks RAS# to CAS# Delay (tRCD) 11 clocks RAS# Precharge (tRP) 11 clocks Cycle Time (tRAS) 30 clocks Bank Cycle Time (tRC) 33 clocks Command Rate (CR) 1T Physical Memory Memory Usage 12 % Total Physical 16 GB Available Physical 14 GB Total Virtual 45 GB Available Virtual 43 GB SPD Number Of SPD Modules 2 Slot #1 Type DDR3 Size 8192 MBytes Manufacturer G.Skill Max Bandwidth PC3-10700 (667 MHz) Part Number F3-2133C9-8GBXH SPD Ext. EPP XMP--2 Frequency XMP--2 Frequency JEDEC #6 Frequency 761.9 MHz CAS# Latency 10.0 RAS# To CAS# 10 RAS# Precharge 10 tRAS 28 tRC 38 Voltage 1.500 V JEDEC #5 Frequency 685.7 MHz CAS# Latency 9.0 RAS# To CAS# 9 RAS# Precharge 9 tRAS 25 tRC 34 Voltage 1.500 V JEDEC #4 Frequency 609.5 MHz CAS# Latency 8.0 RAS# To CAS# 8 RAS# Precharge 8 tRAS 22 tRC 30 Voltage 1.500 V JEDEC #3 Frequency 533.3 MHz CAS# Latency 7.0 RAS# To CAS# 7 RAS# Precharge 7 tRAS 20 tRC 27 Voltage 1.500 V JEDEC #2 Frequency 457.1 MHz CAS# Latency 6.0 RAS# To CAS# 6 RAS# Precharge 6 tRAS 17 tRC 23 Voltage 1.500 V JEDEC #1 Frequency 381.0 MHz CAS# Latency 5.0 RAS# To CAS# 5 RAS# Precharge 5 tRAS 14 tRC 19 Voltage 1.500 V Slot #2 Type DDR3 Size 8192 MBytes Manufacturer G.Skill Max Bandwidth PC3-10700 (667 MHz) Part Number F3-2133C9-8GBXH SPD Ext. EPP XMP--2 Frequency XMP--2 Frequency JEDEC #6 Frequency 761.9 MHz CAS# Latency 10.0 RAS# To CAS# 10 RAS# Precharge 10 tRAS 28 tRC 38 Voltage 1.500 V JEDEC #5 Frequency 685.7 MHz CAS# Latency 9.0 RAS# To CAS# 9 RAS# Precharge 9 tRAS 25 tRC 34 Voltage 1.500 V JEDEC #4 Frequency 609.5 MHz CAS# Latency 8.0 RAS# To CAS# 8 RAS# Precharge 8 tRAS 22 tRC 30 Voltage 1.500 V JEDEC #3 Frequency 533.3 MHz CAS# Latency 7.0 RAS# To CAS# 7 RAS# Precharge 7 tRAS 20 tRC 27 Voltage 1.500 V JEDEC #2 Frequency 457.1 MHz CAS# Latency 6.0 RAS# To CAS# 6 RAS# Precharge 6 tRAS 17 tRC 23 Voltage 1.500 V JEDEC #1 Frequency 381.0 MHz CAS# Latency 5.0 RAS# To CAS# 5 RAS# Precharge 5 tRAS 14 tRC 19 Voltage 1.500 V Motherboard Manufacturer MSI Model 890FXA-GD70 (MS-7640) (CPU1) Version 1.0 Chipset Vendor AMD Chipset Model 890FX Chipset Revision 02 Southbridge Vendor AMD Southbridge Model SB850 Southbridge Revision 40 System Temperature 33 ?C BIOS Brand American Megatrends Inc. Version V1.8 Date 02/24/2011 Voltage +3.3V 3.280 V CPU CORE 1.232 V DRAM 1.640 V +5V 5.003 V +12V 11.968 V
