Motherboard: sabertooth 990fx
Cpu: AMD FX-8150
Memory: Ripjaw X ddr3 1866 8Gx4
im trying to use the ripjaw x 32gb (8GB x 4) with my sabertooth 990fx motherboard but whenever i try to boot up the computer the red DRAM led on the motherboard comes on red and the computer never boots, ive tried using the memok function on the motherboard to fix the compatibility with the ram but that did not work, ive also tried removing and re-arranging the ram just in case one was bad but again, that did not work, at the moment i just have 1 of the 8gb cards in my computer, still getting the led, and i cant find any information on the web so im hoping somebody here might have a suggestion as to what i could try next.
Cpu: AMD FX-8150
