I am having problems with running The 16GB(2x8GB) Ares on its advertised speed.
When running the XMP profile for DDR1600 @ 10-10-10 V1.5, windows always crashes while running prime 95 small FFTs using ram (Custom mode with 12750MB memory to use) This test failed even though the cpu is in stock (no overclock/voltage change in bios). The crash occurs less than 10 minutes from the start of the test every single time.
When running without XMP (DDR1333/667Mhz), the system is stable running the same test whether the cpu is stock, or overclock.
My system is
Intel 3770K/ Gigabyte Z77X-UD5H(BIOS F6)/ Memory F3-1600C10D-16GAO
My system is
