Mainboard Asus P8P67
CPU Intel i3 3.10
RAM F3-10666CL7 2x2GBXH
The question is about timing. When I installed memory, mainboard set up automatically timings to 9-9-9-24 but the memory
can go 7-7-7-21. I changed the timings to 7-7-7-21 CR2(other settings set to auto). Everything works fine, however I noticed that memory clock goes 669 not 667 as normal.
Also cpu clock has increased by few Mhz from 3100 to 3110 and the CPU-z shows bus speed 100,34 Mhz. Is it normal? Are these settings optimal for this memory? I don't want to overclock anything I just want to set best optimal settings.
CPU Intel i3 3.10
