F3-10666CL7Q-16GBXH and ASUS Maximus IV Extreme
  • F3-10666CL7Q-16GBXH and ASUS Maximus IV Extreme
    Bought this set brand new
    Other hardware involved:
    2x Intel SSD RAID 0
    2x Seagate HD RAID 1
    Pioneer Blueray
    radeon Crossfire
    MS Mouse and KB (wireless)
    Firmware is the latest for all hardware including the MB and Videocard
    After a while the system locks up but no ?blue screens?
    Bios setting is XMP 7/7/7/21/2/1.5
    and RAM voltage is 1.58V (1.52V measured'
    Still halting
    What am I doing wrong. Could someone help
    thx
    Iggy
    Try raising VCCIO to 1.14
      VCCIO is raised till 1.14375
        If you have the latest BIOS may want to try simply manually loading the base timings, CR and DRAM voltage rather than letting the mobo set it, even if it appears the mobo is setting it right....if still problems try running Memtest on each stick individually (I'd start with simply 4-5 passes, since it is so time consuming, and see if any problems indicated)
          No more crashes for the last 4 hours
            Sounding good!
              Damn....
              2 more crashes. 1 after a powered computer after a whole night of doing nothing and 1 after 5 houres of use with Chrome and MS Outlook
              All settings done by hand
                Memtest x86 4.0a just stalled during the test
                  If you could post your BIOS settings, maybe we'll see something out of whack
                    CPU installed Intel 2600 3.4GHz
                    Bios setup
                    CPU target freq: 3.8GHz
                    XMP enabled
                    DDR3-1333-7-7-7-21-2N-1.50V
                    BCLK 100.0
                    Turbo all cores
                    PLL overvoltage Auto
                    mem Freq DDR3-1333
                    xtrem tweak enabled
                    EPU disabled
                    DRAM timing 1 level 7-7-7-21-2N all other levels on Auto
                    CPU ratio auto
                    CPU voltage 1.17 manual
                    DRAM Volt 1.50
                    Data ref auto
                    ctrl auto
                    Data ref auto
                    CSA Volt 1.005V
                    CIO Volt 1.144V
                    CPU PLL Volt 1.779Volt
                    PCH Volt 1.058 Volt
                    NF200 1.204 Volt
                      Is there someone with a solution???????
                        Anyone????????
                          Might try DRAM at 1.55 and VCCIO at 1.18
                            Test one module at a time to see if one may be bad causing problems.
