I just recently bought this new MB and some new memory to go with it. The Gskill Sniper Series. F3-17000Cl-11D-8GBSR kit.
I have tried to get my PC stable with Intel Burn Test @ 4.5 and it is a no go. I have tried various settings and I cant get to get there. I have tried XMP mode and does not work. I have tried the DDR3-2133 setting and I cant get it stable there either. I have added more volts to it 1.65v and it locks up on me. I have some older F3-16000CL9D-8GBRM kit and with it.. I can get it stable at 4.5 but it is at 1866 and not the 2133 speed that I would like to get it at. I have LL Enabled, I have added extra Vccsa Volts, I have added CPU PLL Volts added and PCH Volts added.. to get the 2133 memory stable and I have had no luck with it. I have stayed within the Intel Spec for the what SB needs. what other settings can I try to see if I can get it stable at 4.5?
Specs :
i2600k 1.34v 4.4ghz ( stable)
memory v 1.6v ( DDR3 2000 memory ) for the moment
PSU X650 Seasonic
Asus P8Z77-V Bios 0906
Specs :
PSU X650 Seasonic
