Evga x58 ftw3 + f3-12800cl9t-12gbsr2
  • Evga x58 ftw3 + f3-12800cl9t-12gbsr2
    All -
    I've searched through the threads but couldn't find anything on my specific setup. I wanted to see if you had any recommendations for BIOS settings which will A) help out with stability B) help me get those CAS numbers up a little. I'd love to get an 8-9-8-24 considering how low voltage the memory is.
    I appreciate it!!!!
    Could give it a try, I'd try those timings 1.3 DRAM voltage and raise the VTT/CPU Voltage + .06, then let us know what happens
      thank you sir! any advice on other timings? I don't want to use the XMP, so I'm thinking of loading/copying those timings/turning off xmp/putting in timings manually?
      I really appreciate the help!
        Yes, XMP needs to be off, can try the timings you mentioned 8-9-8-24 or 8-9-9-24, then the voltages I mentioned and let me know, I'll be around tonight for a while, trying to get a system tuned up
          Tradesman -
          I gave it a whirl, but my performance took a big hit when I put it at "Default" for the settings instead of XMP Profile and I set the timings manually. When I leave it at XMP and simply set the first timings 8-9-8-24 then the performance increases.
          Is this a problem of not knowing the impact of the more detailed memory settings the EVGA board is offering? (i've never seen some of these settings on my old Gigabyte board) or maybe I'm leaving something out?
          Appreciate the help guys! Let me know if I need to throw up bios template or screen shots.
            May just be a quirk of the mobo model or in the BIOS, if it runs better with XMP enabled and those timings manually, then I'd stick with that
