Hey all -
I built a new PC earlier this month and it has been running great for the most part, with the exception of rare, random app crashes and sometimes BSOD. I've been troubleshooting and have come across errors in Memtest86+ I'm not sure what to make of.
My system:
CPU: Intel i5-2500k (OC'd to 4.5ghz)
RAM: G.skill F3-12800CL9D-8GBRL (9-9-9-24-2N)
Mobo: Gigabyte GA-Z68A-D3H-B3
GPU: EVGA GTX560 ti superclocked
PSU: Corsair enthusiast 750w
My mobo was auto-detecting incorrect timings, so I manually entered them. 9-9-9-24-2N @ 1.5V.
My testing methodology:
So I'm only receiving errors when both sticks are in use. Both sticks individually seem to be fine in either slot (I'm not able to test Slots 3 & 4 because my gigantic CPU fan is blocking Slot 4). See the attached picture for the errors - they seem to be consistently in the same Failing Address range.
Does anyone have suggestions I can try at this point? It seems as if the sticks are OK, but perhaps a BIOS configuration is wrong? I don't know.
Thanks in advance
Uploaded with ImageShack.us
My system:
- Ran Memtest86+ with Stick A in Slot 1, and Stick B in Slot 2 (recommended by mobo manual). Received errors.
- Ran Memtest86+ with only Stick A in Slot 1. No errors.
- Ran Memtest86+ with only Stick B in Slot 1. No errors.
- Ran Memtest86+ with only Stick A in Slot 2. No errors.
- Ran Memtest86+ with only Stick B in Slot 2. No errors.
- Ran Memtest86+ with Stick A in Slot 2, and Stick B in Slot 1. Same errors as Step 1.
Thanks in advance
