I have 2 sticks of memory on my system F3-10666CL9-2GBNQ so, 2x 2GB = 4 GB. I know these memories are rated for 1333 but i tried to Overclock it a bit and is now running at DDR3 733 means at 1466, is there any risk i am taking if it passes memtest and system is stable?
My CPU is also overclocked to the extent it can take, i guess. Actually Phenom II x2 555 BE (3.2 GHz stock), now 2 extra cores unlocked as Phenom II x 4 B55 and overclocked to 3.85 GHz 4 cores. Although it has unlocked multiplier, I had to use FSB instead of multiplier to get Memory Oclocked.
Current setting:
Board is Gigabyte GA-870A-UD3.
CPU : 3.85 GHZ (220 FSB x17.5)
HT : 1980
NB: 2419 , NB voltage : 1.12
Memory :1466 DDR3 (means 733 MHz) voltage 1.52
If the system is stable for Primetest, temps under control, and mempry passes Mtest, is there anything i need to be worried about running this memory (rated 1333) at 1466 with slight bump of voltage?????
thanks
Current setting:
HT : 1980
thanks
