Model of the motherboard: Asus Rampage 4 Extreme
Model of the memory: f3-12800cl9q-16gbzl
Model of the CPU: Intel 3930K
Hi there,
I am having an issue with this RAM. I am running the RAM with gskill recommended XMP on, Rampage Tweak Mode 1, 1.25V VCCSA, 1.5V vdimm.
When I run 1 stick, 2 sticks or 3 sticks the system is stable and does not BSOD. When I run with 4 sticks installed the system will BSOD sometimes in an hour, sometimes longer, faster if I run a game or stress test program. I have tried using 1 stick at a time and it does not matter what sticks I use, all work okay with 1-3 sticks installed, but once I install all 4 sticks, the BSOD will happen.
I have tested memory with memtest86+ and it all passes.
Please advise Gskill, ram is passing memtest86+ 4 passes but can only run with 1,2 or 3 sticks installed. All 4 sticks installed = BSODs after 30 minutes to 2 hours of system being on.
Hi there,
