Ripjaws-X F3-1600C9Q-32GXM two xmp profiles?
Last edited by Tenchi; 03-02-2012, 05:49 AM.Intel i7-980X @ Noctua NH-D14 | Asus Rampage III Extreme| MSI GTX580 Lightning XE | 24GB G.Skill DDR3-1600 CL7 F3-12800CL7T-12GBSR | Intel X25-E 64GB & X25-M 80GB | 3x600GB WD6000HLHX VelociRaptor & 1xWD2001FASS 2 TB | Teac DV-W5000S & Pioneer DVR-216D | Seasonic X-650 | Lian Li TYR PC-X2000F @bequiet Silentwings USC |
Tags: None
Mostly, that text doesn't mean anything. When you select a profile in BIOS, you gotta check the settings yourself and compare to advertised settings on the sticks or boxing, timings, speed and voltage.
For example, mine says 9-8-9-25-1t 1.6v on the xmp profile. But it sets 8-9-8-24-2t 1.6v in bios, which is correct according to specs on its webpage or label on the ram. So it sets correctly but the text is wrong.This cat scratches free.
Intel i5 2500k @ 4ghz Offset - 0.015v | Asus P8P67 EVO | 12gb GSkill RipjawsX F3-14900CL8D-4GBXM 2x2gb & F3-14900CL9D-8GBXL 2x4gb 1866 9-10-9-28@1.6v | AMD HD6850 1GB | Enermax Infiniti 650w (28a,28a,30a) | 2xWD500 Caviar Black & Blue | CM Haf-912 Advanced | Noctua NH-U12P SE + Akasa 12cm Viper | Windows 7 Ultimate x64 SP1 | AMD Catalyst 13.10b
oh, that good news
Yes, with the release of the X79 and ver 1.3 of XMP, GSkill is taking some of the models that have been around awhile and adding XMP 1.3 settings to the SPD, generally it's near same and more likely to be seen in the advanced timings
