DDR3 1333 Model F3-10666CL9Q-32GBXL and ASRock Z68 Extreme7 Gen3
  • DDR3 1333 Model F3-10666CL9Q-32GBXL and ASRock Z68 Extreme7 Gen3
    I would like to know if the DDR3 1333 Model F3-10666CL9Q-32GBXL sold as a 32GB kit is compatible with the ASRock Z68 Extreme7 Gen3 and, ASRock Z68 PROFESSIONAL GEN3.
    Those are the two motherboards I am considering at this time and ASRock does not list that particular GSkill memory kit in their compatibility list.
    Thank you for your help,
    John.
    PS: just FYI, when I click on the "search this forum" button (in the DDR3 forum), nothing happens. It does not seem like the button is working.
    Yes, no problem, make sure you have the latest BIOS, the Ripjaws X models were designed around the Z68/P67/H67 chipsets.....and yhey are looking into the search thing, had problems with it over the weekend also
      Tman, thank you very much for the prompt reply. Much appreciated and pleased to learn that the kit will work with the motherboards I am considering. :-)
        Let us know how it goes and how you like the sticks and combo
