Hello all,
System had 8Gb's mem and can max to 16Gb's. Have bought above mentioned but bios only shows 8Gb's. They are installed as manual said and moved them to other slots, upgraded bios to latest and even re-installed previous 8gb's.
What do I do to get 16Gb's to show in BIOS and Windows??
Green Chieftec case
GIGABYTE GA-890GPA-UD3H FF
AMD Phenom II x4 955 be 3.20GHz
G.SKILL F3-17000CL9D-8GBSR
1 WD Cav 7200 320GB and 2 WD Cav 7200 150GB
Windows 7 Pro x64
Green Chieftec case
Windows 7 Pro x64
