First off, I would like to say that both my first and 2nd set passed memtest 10+ times with no errors. Around a week later 1 stick out of both kits began to fail.
Board: gigabyte 990fx-ud3 (tried both f5 and f6e beta bios)
Processor: FX-4100 @ both stock speeds and OC to 4.6ghz (just raised multiplier to 23 and voltage to 1.42)
Timings: both default reading only 1600 and at 1866 with 9-10-9-28 @ 1.5v
Slots utilized: 1 and 2 as per motherboard recommendations
So i had the first kit and everything was running smoothly. Out of no where the stick in slot 2 started throwing errors. Tried it in my other 3 slots and it continued to fail.
The stick in slot 1, the good one, passed memtest so I tried it out in slot 2. It passed there as well. No biggy, I thought i just had a bad stick, so I RMAd it back to newegg.
A few days later I got my replacement set and ran memtest again. Again, both sticks passed memtest without a hitch. Now, just hours ago, I got my first BSOD since replacement. I decided to run memtest and the stick in slot 2 is causing errors now. Once again I tried it in slot 1 and it continued to produce errors. The other stick passes.
On another note, while running prime95 for an hour or so, I dont get any errors.
I find it hard to believe that both kits have a bad stick. Is there a compatibility issue with this particular ram and my motherboard/CPU?
Kind of at my wits end about this and would like get my new system running without a hitch!
Any help would be appreciated!
