I've just purchased a P8Z68-V Pro. The only G.Skill RAM i could obtain was
Ripjaws Z GS-F3-12800CL9Q-16GBZL.
Apparently the correct RAM for that mobo is [ RipjawsX ] F3-12800CL9Q-16GBXL. I checked the specs and there doesn't seem to be much, if any, difference between them:
1) will the RipjawsZ work OK?
2) If so, are there any limitations on its function or performance compared to the RipjawsX?
3) Will I need to make any manual adjustments?
4) what is the functional difference between the two?
SOrry to ask so many questions, it's a bit confusing for a G.Skill "virgin"
Cheers,
Brian
Cheers,
Brian
