I have the following system:
MB: Intel DX38BT
CPU: Intel(R) Core(TM)2 Quad CPU Q9450 @ 2.66GHz
I bought F3-10600CL8D-4GBHK memory and wanted to use it together with currently installed Kingston KVR 1333D3N8K2/2G.
Unfortunatelly, when I press the start button computer gives me three sound signals and do not do anything else.
When I try to use either pair of memory modules, they work fine. Together they don't work at all.
I tried to start them with default(Automatic) settings in bios, but without success.
Also I noticed that bios show 8-8-8-24 latencies for Kingston.
For G.SKILL it is 9-8-8-24 even when I select XMP.
They both run on 1333MHz.
So, there are two questions:
1. How I can make two memories work together?
2. How I can make G.SKILL (when it is the only pair of memory installed) to run on the latencies (8-8-8-21 1.5V) claimed for this memory by the manufacturer?
Thank you.
MB: Intel DX38BT
Thank you.
