Forum:
I currently am running my rig a GA X58A-UD7 / i7 920 D0 / 12g of G.Skill modules stably @ 4.0 but would like to flirt with tighter timings which should help push the rig to the next level.
Here is what we have installed:
8g (2x2g) F3-12800CL7D-4GBRM Type 240-Pin DDR3 SDRAM Tech Spec Capacity 4GB (2 x 2GB) Speed DDR3 1600 (PC3 12800) Cas Latency 7 7-8-7-24-2N .
4g (2x2g) F3-10666CL8D-4GBRM Type 240-Pin DDR3 SDRAM Tech Spec Capacity 4GB (2 x 2GB) Speed DDR3 1333 (PC3 10666) Cas Latency 8 8-8-8-21.
My question is since there are 3 modules of G.Skill Ripjaws with two different latency and timings what is a safe advanced timing setting in my bios for each of the modules? And how do we go about making the changes in the bios.
E
E
