I'm looking for 8GBKit for my system GA-78LMT-S2P + FX-6100. I tried the memory configurator but my motherboard is not supported. can anyone suggest me the most compatible gskill 8gb kit for me?
8GB Memory for GA-78LMT-S2P + FX-6100
Guessing you'll be wanting 1333, so I'd suggest one of these:
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007611%2050008 476%20600006050%20600006131%20600006069&IsNodeId=1 &bop=And&CompareItemList=147|20-231-417^20-231-417-TS%2C20-231-311^20-231-311-TS%2C20-231-426^20-231-426-TS
there are some others, i.e. low voltage, tighter CL, but I think these would be the best bets
thanks Tradesman, reading the link, i notice that only the sniperG .SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory has info which state "compatible with am3+". will the other 2 not compatible with am3+ ?
and also will F3-10666CL7D-8GBXH work for my need?
All will work with AMD3+ (the Snipers are amoong my favorites as they are very versatile and both OC and underclock very well)....... The Ripjaws X set you mention will probably work, but may take more manual setup, since it's a native CL7 which is tight for AMD CPUs, so you may need to run higher DRAM and/or CPU/NB voltage, lower the CL and performance or drop the freq from 1333 to run at CL7
