Motherboard: Asus Sabertooth P67 Bios Version 1904
Memory: F3-17000CL8D (4x2GB)
CPU: Intel i7-2600k
I am currently running at 3.8ghz (reference 3.4ghz) on my cpu. My voltage is set to offset +0.05 (usually runs at 1.264v during memtest and sub 60c.) My DRAM voltage is 1.65 and my timings are 8-9-8-24-2N @ 2133mhz. My VTT/QPI is set to auto (0.925v) After running memtest I am receiving error(s). I was also receiving hardware failure warnings on Prime95 Blend and Large FFT.
I initially was running at 4.4ghz with the same voltage set up and was failing memtest. Thinking it could be due to the OC of my CPU I increased my ram timings to 9-11-10-28-2N. I once again failed memtest. I then removed the OC on my CPU altogether and ran at 8-9-8-24-2N and also failed.
I have not removed any sticks yet. But after running at hilariously slow (in comparison to the advertised timings) speeds and failing memtest I figured there's something more I was missing and/or had bad ram.
CPU: Intel i7-2600k
