Mobo Gigabyte GA-770TA-UD3
CPU Phenom II x4 965 BE Oc 3.63GHz, BSCLK 201, mult 18
GFX Radeon HD4600
OS Windows 7 Ult 64bit
HDD Seagate 500GB
RAM F3-12800CL7D-8GBRH, 2x4GB, 7-8-7-24, 1.6V, 1600
NB 1.4V
CPU-NB 1.2v
I have RMAd this mobo two times due to a no POSTing issue. IT will run fine for several days and then on a reboot several things have happened.
1. Goes into a reboot loop
2. Startup Repair loop without a fix
3. Blank screen
Resetting CMOS helps some and then I will get nothing but a blank screen which a CMOS reset does [B]not[B] help. I decided to pull one stick of RAM and voila! it worked again normally.
Memtest has been run for 8 hours, 7 passes with no errors. Tested each module in different slots without errors as well. Having two slot populated doesn't work even though memtest says the RAM is good.
I have also tried booting with no drives, two different drives and a USB stick to no avail when I get the black screen. I have switched GFX cards (GTX460), no help.
Seems this RAM is somehow defective although it tests good. I also tried to boot to a DVD, including a Windows DVD. All fans and lights work, but no POST.
Ideas welcome, RMA?
Gary
GFX Radeon HD4600
HDD Seagate 500GB
NB 1.4V
CPU-NB 1.2v
3. Blank screen
Ideas welcome, RMA?
Gary
