I purchased a set of F3-12800CL9D-4GBRL as a kit and have used it for almost 2 years. I recently purchased a second set of the same kit F3-12800CL9D-4GBRL both purchased from http://www.newegg.com/Product/Produc...82E16820231277. After receiving the second set I installed them next to the set I had and had no issues at first. After a few hours I started getting lockups and blue screens. I had run Memtest86 on each stick finding that one of my old sticks had errors and one of the new sticks had errors as well. I did receive an RMA and have shipped the sticks to be replaced.
I have rerun the tests on the 2 remaining sticks as a single and both passed all 5 runs of Memtest86. I re-installed both sticks and rerun Memtest86 once more and at this time the memory errors start appearing. I have run Memtest for windows with no errors. Is it possible that the memory sticks have issues with each other? Windows runs fine and i have had no issues while inside of windows. How can I fix this or should i worry about this?
My system Specs:
AMD Phenom II X4 955 @ 3200 with Corsair H70 watercooler
Asus M4A785T-M with newest bios
G-Skill F3-12800CL9D-4GBRL @ 1600 9-9-9-24 1.5v
Raid 0 Running Windows 7 64bit
4 other storage HDDs
Pioneer DVD-/+ DL Writer
BFG GTX260 MAXCORE
Corsair GS700 watt PSU
I have tried different settings and all seem to work fine in windows but still error if the 2 sticks are run together in Memtest86.
I have also went to the forum and was going to post this question there but it will not let me post yet. As stated they test out fine as a solo chip but error in Memtest86 as a pair. I have them run in dual channel and have also separated them to run in different banks as single channel with the same results. I have tried the following settings to try to figure this out:
9-9-9-24 1.5v
8-8-8-25 1.5v
9-9-9-25 1.5v
I have read on the forum to raise the CPU/NB up to 1.20 from 1.10 but there is no setting for CPU/NB volts only a multiplier. Any ideas? Thanks <-- I figured this out but no help.
Update: I used Memtest86 v4.0a on all these tests. I have retested using Memtest86 v3.5 and it kick out so many errors i had to stop it. Run Memtest86+ and it run successfully through 5 runs of tests. Could this be a software error instead of the memory? Maybe the software doesnt support my MB well? starting to wonder if the RMA memory was bad after all.
My system Specs:
BFG GTX260 MAXCORE
9-9-9-24 1.5v
8-8-8-25 1.5v
9-9-9-25 1.5v
