Hi all, I'm new here and luckily without any issue (yet). Of course, I'm asking for an update soon to come (as soon as you'll clarify my doubts).
I'm happy with my mobo and my Phenom II AMD X3 720 (C2 step) upgraded to a fully working X4 3.4Ghz one.
Now, I've been reading pretty much these days to try to get what can be tricky when upgrading ram on a quite old mobo and an amd cpu. So I decided to be somehow conservative and do not try to get the 1600 ones but try to max out my 4 slots with 4x4Gb 1333 sticks.
My mobo should support up to 32 Gb (they say/claim) and any voltage from 1.5 to 2.5V but I'm far from being optimistic when going to buy "only" 16 and let them work in dual channel. Fortunately I've read this from your general section:
So, these where the sticks I wanted to buy (in order of preference):
1- Ripjaws-X F3-10666CL7Q-16GBXH 1333MHz 16GB (4x4GB) CL7-7-7-21 1.5v
2- Ripjaws-X F3-10666CL7D-8GBXH 1333MHz 8GB (2x4GB) CL7-7-7-21 1.5v
3- Sniper 8GBSR 1.5V CL9
here come the questions:
1- do 1 and 2 just differ in the size amount, being buying two n?2 the same as one n?1?
2- the vendor list shows all these sticks compatible both for INTEL Socket 1155/1156 and AMD AM3 while in the specs I can see only intel mobo supported by 1-2 and an asus M4A79T Deluxe mobo for n?3, which is almost as mine with a 790FX NB instead of 790X (no 16x xfire/sli support on mine). Can you confirm that 1 and 2 are ok with my mobo/cpu? In case the answer is "no" could I have any problem rigging two n?3s in order to have 16Gb on the 4 slots? Can you confirm that I can use all the 4 slots in dual channel using the standard values? Shell I use the bios manual setting or may I just leave them all in auto? Is there any bios setting I can change to max them up without changing any voltage?
Guess that's all
Thanks in advance
Max DDR3 and DDR2 on AMD motherboards
I just got a reply back from Gigabyte about running the 16GB max stated on their site for my AM3 mobo and I'm sure a few others. I asked what type and speed RAM I would run to get the 16GB. I was curious and don't intend on running that much. Here is their reply. ( The more memory installed in a system, the harder to synchronize at faster speed and there will also be limitations on the AMD memory controller. For example can run 1600MHz but 1 DIMM per channel maximum. If you have 4 DIMMs, 1333MHz is the maximum supported memory speed. If going to load it up with 16GB, stick to standard DDR3 memory like 1066MHz or 1333MHz 1.5v memory. Thank you.)
Guess that's all
Thanks in advance
