Hey there. New to the GSKILL Forums but not new to forums in general, so please refrain from the "try searching, noob" comments. Trust me, I have. If you want to link me to a specific forum thread pertaining to my problem, then great.
Buying the Asus Crosshair V Formula board, and an AMD FX-8120 cpu. My problem is with what RAM to acquire. Right out of the starting block I wanted to buy the GSKILL Ripjaws X series 16gb (4x4) 2100 but after some research, found that Asus will not support this memory set with 4 dimms for the two channels. --Is this correct information?
Also, noticed that the clock frequency limit supported by the FX-8120 was 1866mhz, but then seeing plenty of people having issues with running this setup stable, and reverting back to 1600.
So my bottom-line question. Is running this setup possible with 2100mhz OC'd memory, and if not, is 1866mhz, or do I need to go down to 1600? Basically, I want to buy the fatest STABLE memory set for my system, but I also want 16 total GB. (Unless someone can explain why a faster 8gb would be more beneficial than slower 16gb)
Thank you very much, for all your help!
A bit of background, I'm very comfortable with "tweaking" and poking around the BIOS. If I get specific instructions, I have no problem setting voltage and timing. I just want to make sure I'm not going to BSOD every few hours.
-J
-J
