F3-10666CL9D-16GBXL - Freeze/Reboot
  • #16
    Crap. Hoping that would do it. No dice.
    Thanks again for all your help.
    Just curious, but should I have bought different DIMMs, or are the ones I have compatible? It just seems so strange that either stick works by itself, in either slot, but not two together, even with more juice.
    • #17
      Should be fine with the mobo, maybe the BIOS still isn't up to snuff, could drop them a line asking, in the meantime could try raising the DRAM voltage up a bit more, maybe even to 1.6 which is still safe
      • #18
        Increase Row Cycle Time to 40
        Write Recovery Time 14
        • #19
          Upping the dram voltage seemed to make it crap out sooner in the boot process.
          Upping the RCT and WRT seemed to have a positive effect. Windows stayed up for almost 5 minutes but then still rebooted itself.
          • #20
            VDD/NB to 1.24
            • #21
              I can't set it to 1.24 but neither 1.2375 or 1.25 make a difference.
              Don't know if any of these settings are relevant but I realize I didn't include them in my other post.
              • #22
                There was a bios update available for my motherboard, so I installed it and retested with various settings. Unfortunately, there was no change, it still reboots itself with both dimms in.
                • #23
                  Will see if we can get GSkill to chime in
                  • #24
                    That would be great! Thanks again for all your assistance.
                    • #25
                      Have you tried 2 and 4?
                      Feel free to send the memory in for RMA if you continue to have problems.
                      • #26
                        I think you are asking about slots but I am not sure.
                        This MB has two slots. Either of the DIMMs works fine alone. The issue is when both are in. I know the slots aren't bad as two 4GB g.skill's that i have work fine.
                        What is your RMA process. Can I get replacement RAM and then send in mine? Like I said, I can use one stick and have a working rig.
                        Thanks!
                        • #27
                          Will want to talk to the RMA folks @ rma@gskillusa.com info can be found here:
                          http://www.gskill.com/rma.php
