Hi there!
I haved two memory packs from G.Skill:
- G.Skill Ripjaws DDR3 1600 2x2GB (July 2011)
- G.Skill Ripjaws DDR3 1600 2x2GB (November 2011)
I'm testing both of them on a Gigabyte FXA990-UD3. The July pack is auto-detected and configured at @800, but I have problems with the November pack.
Here it is the info I got from Aida 64. I have one module of each pack mounted on my MB:
July RAM:
November RAM:
If I configure the November pack manually to run at 1600, the system becomes unstable on about 10 minutes of intense use... I'm about to RMA this new RAM, but just wanted to know if this is a known issue or just a bad pack...
Sorry about my english level, I'm trying to do my best.
Best regards!
July RAM:
Campo Valor
Propiedades del m?dulo de memoria
Nombre del m?dulo G Skill F3-12800CL9-2GBRL
N?mero de serie Ninguno/a
Tama?o del m?dulo 2 GB (1 rank, 8 banks)
Tipo de m?dulo Unbuffered DIMM
Tipo de memoria DDR3 SDRAM
Velocidad de la memoria DDR3-1600 (800 MHz)
Ancho de bus del m?dulo 64 bit
Voltaje del m?dulo 1.5 V
M?todo de detecci?n de errores Ninguno/a
Fabricante DRAM G Skill
Tiempos de Memoria
@ 800 MHz 9-9-9-28 (CL-RCD-RP-RAS) / 37-128-5-12-6-6 (RC-RFC-RRD-WR-WTR-RTP)
@ 711 MHz 8-8-8-25 (CL-RCD-RP-RAS) / 33-114-5-11-6-6 (RC-RFC-RRD-WR-WTR-RTP)
@ 622 MHz 7-7-7-22 (CL-RCD-RP-RAS) / 29-100-4-10-5-5 (RC-RFC-RRD-WR-WTR-RTP)
Extreme Memory Profile
Nombre del perfil Enthusiast (Certified)
Voltaje 1.50 V
Caracter?sticas del m?dulo de memoria
Auto Self Refresh No soportado
Extended Temperature Range Soportado
Extended Temperature Refresh Rate No soportado
On-Die Thermal Sensor Readout No soportado
Fabricante del m?dulo de memoria
Nombre de la empresa G.Skill International Enterprise
Informaci?n del producto http://www.gskill.com/products.php
Tiempos de Memoria
Voltaje 1.50 V
November RAM:
Campo Valor
Tama?o del m?dulo 2 GB (2 ranks, 8 banks)
Velocidad de la memoria DDR3-1333 (667 MHz)
Tiempos de Memoria
@ 609 MHz 8-8-8-22 (CL-RCD-RP-RAS) / 31-68-4-10-5-5 (RC-RFC-RRD-WR-WTR-RTP)
@ 533 MHz 7-7-7-20 (CL-RCD-RP-RAS) / 27-59-4-8-4-4 (RC-RFC-RRD-WR-WTR-RTP)
@ 457 MHz 6-6-6-17 (CL-RCD-RP-RAS) / 23-51-3-7-4-4 (RC-RFC-RRD-WR-WTR-RTP)
Voltaje 1.50 V
Tiempos de Memoria
Voltaje 1.50 V
Best regards!
