I have the Quad-Channel 2133 (4x4gb) set @ CL9 and am using 3 sticks on a X58 in triple channell until I get the X79 motherboard.
The XMP profile has only 1.2v on QPI/DRAM voltage with 1.66V on DRAM voltage. It will not even POST with this, to get the system to boot windows, I had to set the profille to 1 and raise the QPI to 1.7 (same as the kingston ddr3-2000 memory I had previously).
If i try to use profile 2 at 2133, it only registers 8gb instead of 12gb, I have also had 2 BSOD today even at 2000.
Are there any other settings I should be changing to make the system more stable?
Motherboard - Asus P6T Deluxe v1 with 2209 bios
Processor - Core i7-950 stock clocks
Memory - F3-17000CL9Q-16GBZH (4x4gb but using 3x4gb in triple channel)
Thanks,
Jez
Thanks,
Jez
