7-8-7-24 vs 9-9-9-24 1600MHz
  • 7-8-7-24 vs 9-9-9-24 1600MHz
    Greetings G-Skill!
    I currently have the 2x2GB 7-8-7-24 1600MHz Ram, but I was looking to up to 2x4GB 9-9-9-24 1600MHz RAM seeing the deal they have on NEWEGG today....
    Would I notice a performance drop in this "upgrade"?
    Possibly a hair down here and there, but the addition of an extra 4 GB will negate it based on what you do
      Thanks for the quick (and helpful) response =) Always quick to the draw Tradesman!
      Any word as to common/stable overclocks to this RAM set? Didn't see anything on the forum.
      http://www.newegg.com/Special/ShellS...6-_-11162011_3
        Which set are you looking at, the link above is to a seasonic PSU
          Sorry, stupid newegg links X-D
          http://www.newegg.com/Product/Produc...82E16820231314
          Try that!
            I've run some at a little over 1800 with CL9-10-9-28, then again I've had a few that would run 1800 but had to go to a tight CL10
