Question about ripjaw x compatibility
  • Question about ripjaw x compatibility
    i am looking to upgrade my memory for 3 different mobos. the speed is for all 3 is ddr3 1333 and dual channel so it should be able to use the F3-10666CL9D-8GBRL
    but when i check the compatibility list it says it is not listed
    these are the motherboards
    Gigabyte GA-770T-USB3
    Gigabyte X58A-UD3R
    EVGA 132-CK-NF79
    The sticks should be fine with all three mobos, may want to check the sticks again though you mention RipJawX in the title but the model you list is regular Ripjaws..either will be fine the X or reg Ripjaws at 1333, just make sure it's not something different
      tyvm and my mistake i had meant for the ripjaw x and just wondering what is the difference between the ripjaw x and ripjaw? is the x series better in quality or speed?
        The X series is sort of a step up, and was designed towards the newer gen CPUs and chipsets (i.e. the P67, Z68 and I25-2600K CPUs, but are backward compatible with generally all chipsets
