I got a bundle of 2x4gb gskill sniper 1866 compatible with intel z68 ( F3-14900cl9d-8GBSR ).
Unfortunatly i got some problems playing games , like little freeze or fps drops in certain situations. I'm pretty sure that is a RAM issue cause i tried 2x2gb (gskill ripjaws ) of a friend and their going well.
when i understood that the problem was "Ram" i used memtest and it went good so those ram are ok ,and probably i need to fix something..
I updated the Bios of Asrock z68 extreme 4 to latest version ( 1.70 that support xmp1.3 ) after that i loaded xmp 1.2 ( @1866 9-10-9-28 1t ) ... now situation is better but still i can notice the problem. ( i didn't got a xmp1.3 , just 1.2 dunno if it is normal )
my cpu is an intel i5 2500k and it is oc to 4.6 ghz with intel optimized configuration ( vcore is around 1.35/1.37 on auto and i think it's a bit higher than normal , but this should not be a prob ) .. vram is 1.5v on auto.
i tried also to run those Ram to 1600@ 8-9-8 24 1t , and nothing changed.
PS: i also played prime95 for 2h running cpu stress test and than for 1h running ram stress test ... the results were good ( no problems detected ).
i don't know what to do :/ thks for help, hope u can help me.
sorry for my bad english.
