Hope this is the right place to post this question.
I am in the process of building an AMD machine and I understand that I will need to tweak the ram settings in the bios to get the rated speed the G.skill ram is said to have.
I have built a few systems but never tweaked these types of settings before. Could someone point me to a possible thread explaining in detail how to do this? Different forums seem to have different advice on what the settings should be. Hoped I would cut to the chase and ask the experts here.
I also gather that I should update the Bios first before tweaking the settings to Gigabyte version f9.
CPU: AMD FX-4100 Zambezi 3.6GHz Quad Core
Mobo: GIGABYTE GA-990XA-UD3
RAM: G.SKILL Ripjaws F3-10666CL7D-8GBRH
(Specs say it will run at: DDR3 1333, CAS Latency 7, Timing 7-7-7-21, Volts 1.5)
GPU: SAPPHIRE 100315L Radeon HD 6850
PSU: Cooler Master RS700-PCAAE3-US 700W
So what will I put the settings at to run at this spec? Any advice is appreciated.
