Hey guys. While I consider myself moderately tech savvy, in actuality I probably only really know just enough to be dangerous. I'll try to provide as much information as possible:
I've been running this system for the past 2 years with no problems (built myself):
MSI 790FX-GD70 mobo
AMD Phenom II x2 550
4 sticks (8GB) of F3-12800CL9D-4GBNQ
Sapphire 4870
I just purchased:
AMD Phenom II x6 1090T
4 sticks (16GB) of F3-12800CL9D-8GBXL
I currently have Bios V1.3 on my board (old), and will need to update it before installing the CPU. I have the newest version downloaded, but am not 100% sure about how to update it, other than the fact that if I screw up my computer is a brick. The extracted file has a readme, howto word doc, an executable, and a .1h0 file. Will running the executable in windows update successfully? I really don't want to have to make a boot disc and do it the other way, but will if there is no other option.
Also, anyone know if updating bios to the newest version (1.X) well fix any problems with the memory I'm having? Before swapping out the CPUs I tried installing the RAM just to confirm it would work. With all 4 sticks in (16GB) the computer will not boot. Taking all but 1 stick out lets me enter BIOS, but with little experience I wasn't sure what to change, and even with just 1 stick the computer freezes up after just a couple minutes.
Thanks for any help you can provide!
-Jbs
MSI 790FX-GD70 mobo
Sapphire 4870
I just purchased:
-Jbs
