F3-12800CL9D-8GBRL (4Gx2) + Maximus IV Extreme Z
  • F3-12800CL9D-8GBRL (4Gx2) + Maximus IV Extreme Z
    i7 2600K CPU. Asus Maximus Extreme IV Z motherboard, Ripjaw Gskill F3-12800CL9D-8GBRL (4Gx2)
    By default this ram is running at 11-11-11-28 1.65v set by the MB. When I use the XMP settng in bios it uses the correct timings for the memory 9-9-9-24 1.5v but OC's my PC from 3.4ghz-3.8ghz and I have some slight explorer.exe freezes no reboots. I can even use taskbar to stop explorer and the desktop comes back to normal so not even a log off.
    How can I stabilize this and what are the manual settings for this board using this Gskill ram.
    My CPU is i7 2600K
    This is my first Gskill memory. No-one responded to my post 2 days ago. I also send email no reponse. Corsair forums always gave quick responses but here nothing for days. I really don't know where else to go.
    Make sure you have the latest BIOS, if problems persist, try raising the DRAM voltage .05
      Do you mean from 1.5 to 1.2?
      Thanks I have to install the latest bios also.
        Install the latest BIOS....Done? As mentioned above if problems persist raise the DRAM voltage + .05 ---not sure wher you came up with 1.2-------but rhese are 1.5 sticks , so plus .05 would be to 1.55
          Sorry about that I'm new to all this yes 1.55
            Ok. I updated to the latest bios 706 and applied XMP now I'm running at 3.8ghz 9-9-9-24 1.5v which is sweet!
            In bios all memory settings are on auto and I can't change anything. Is there somewhere to turn on manual ram settings? Only had this mb for a few days so I haven't got a clue.
            At least I got my bios updated thanks to your advice. The new bios update might correct the issue. Should I wait a couple of days and if no crashes then not apply the extra voltage or apply it now?
              Actually I just checked dram voltage is 1.495 stable
                I know this sounds silly but how do I turn off auto ram settings in bios? Maybe I'm missing something small here but when I click on auto in bios no option is offered for manual. Am I looking in the right place?
                I just updated my bios and want to increase ram voltage to 1.55 as advised above but all ram settings are on 'auto' and I haven't yet discovered where I turn auto off. I've only had the board a few days.
                  ok I figured it out.
