I'm running two sets of this memory (total of 4x 2Gb) in a Gigabyte GA-890gpa ud3, rev. 2.0 mobo with a 1090t (@ 3.8Ghz...for now).
The memory is listed as 7-8-7-24-2n. Using the sticky instructions in this forum, I've manually set the BIOS to 8-8-8-24, 2t. I've upped the BIOS to 1600 mhz and the voltage to 1.6. The NB freq is now 2400.
All is good...
What about all the other memory timings? The default/auto settings were all much looser than what the memory is rated at. Bank cycle, tRC, shows 40. It seems it could be lower. Would I gain any measure of performance increase? What about all the rest?
TwTr Command Delay
Trfc0 For dimm1
Trfc2 for dimm2
Trfc1 for dimm3
trfc3 for dimm4
Write recovery time
Prcharge time
row cycle time
ras to ras delay
Is it worth changing these? If so, how do I find the ratings?
Thanks,
Ken
All is good...
TwTr Command Delay
Trfc0 For dimm1
Trfc2 for dimm2
Trfc1 for dimm3
trfc3 for dimm4
Write recovery time
Prcharge time
row cycle time
ras to ras delay
Thanks,
Ken
